Project Heavy Case
tomisafish
RAM: Mushkin 8GB 1600MHz
GPU: EVGA GTX 670
Cooling: Open water loop
Re: Project Heavy Case
Sat May 26, 2012 11:24 am
Well, it all seems to working fine. If I can get to the store to get distilled water I will probably do this water cooling tomorrow.
And wow this 670 is quiet. Running games on ultra high and I cant hear a thing.
tomisafish
GPU: EVGA GTX 670
Sun May 27, 2012 11:01 am
So, I feel pretty confident about everything except for getting air bubbles out. I'm not really 100% what I should be doing in regards to this. As far as I understand, I get everything in place, fill up my reservoir/pump, turn it on, top up reservoir/pump and then close it. After doing that I want to just let it run and move the case around a bit?
Sun May 27, 2012 2:44 pm
basically yes, when the system is running the air will slowly work its way out of the system. Once you see the water settle and it will appear stationary without any visible bubbles you can tilt the case side to side just to get the last few out of the radiator and water blocks.
tomisafish
GPU: EVGA GTX 670
Sun May 27, 2012 2:53 pm
Well, I was gonna get it done today but then it dawned on me that I am gonna have 6 fans in my case and only 3 headers on my mobo. Gonna grab one of these at the end of next week.
Sun May 27, 2012 4:00 pm
I have that exact one on my own computer. It works quite well. I even have nine (!!) 120mm fans running off ONE channel on that fan controller. Really high quality looks nice too.
Sun May 27, 2012 4:19 pm
Pri wrote:I have that exact one on my own computer. It works quite well. I even have nine (!!) 120mm fans running off ONE channel on that fan controller. Really high quality looks nice too.
... Oh...
tomisafish
GPU: EVGA GTX 670
Wed May 30, 2012 6:55 pm
It has been ordered. I hope to have everything done by the end of next week.
tomisafish
GPU: EVGA GTX 670
Sun Jun 10, 2012 12:05 pm
OC'ed to 4.2GHz today. Reaching a max of 56c on 100% load. I am content :)
aaanndd
Finally some pics!
(will get round to cleaning of fingerprints sometime)
http://valid.canardpc.com/show_oc.php?id=2400962
Sun Jun 10, 2012 12:46 pm
Looks so nice. The black coiling around the tubing really adds to it.
and GTX 670 <- Me jealous.
crazyspazman
RAM: 8gb DDR3 1600 mhz
Display: crappy mc crapperson
Sat Jun 23, 2012 3:05 am
kind of old thread, but how is the 670 holding up? and also, do you have a 3-monitor set up?
im wondering because im debating whether or not i will need a 670 with 4 gb of vram, or just 2.
i will probably go with the 4 however, its only 30$ more.
Return to “Hardware Hangout”
