What IC's & Mechanics do you want enabled from Craftbook?
Re: What IC's & Mechanics do you want enabled from Craftbook
Tue Feb 24, 2015 3:45 am
I don't have permissions to use Message Emitter mechanic
PartyGras
Wed Feb 25, 2015 2:09 pm
Teleporter signs
Less complicated version of the current craftbook teleporters
http://wiki.sk89q.com/wiki/CraftBook/Teleporters
H2oDragon83
Thu Feb 26, 2015 6:53 pm
IC / Mechanic Name: XP Storer
Description of what it does: allows a player to convert their XP into bottles of enchanting.
Link to it on the Craftbook Wiki: http://wiki.sk89q.com/wiki/CraftBook/XP_Storer
Riven
Thu Feb 26, 2015 8:43 pm
Pri already responded to that one h2o
Pri wrote: The ones posted above that were not added such as XP Storer, Tree Lopper, Cauldron, Cooking Pots, Item Collector and Block Breakers were not added as I feel they alter the gameplay or replace pre-existing mechanics in too greater way.
EmberCelica
CPU: i7 6700k
RAM: 16GB DDR4
Motherboard: [Unknown]
GPU: AMD RX480
Cooling: Fan Cooling
Sun Mar 01, 2015 1:52 am
IC / Mechanic Name: MC5000
Description of what it does: This allows for PLC's. If we want to take the time to mill through the code then we can create so much more complex and compact things. So for example i could condense a complex 6-bit Combination lock into a single block(aside from input and output connectors) as shown on the perlstone coding language page.(link below)
MC5000 Page: http://wiki.sk89q.com/wiki/CraftBook/MC5000
Perlstone Language page: http://wiki.sk89q.com/wiki/CraftBook/Perlstone
BioZombieActive
Mon Mar 02, 2015 5:19 pm
IC / Mechanic Name: The use of Filters on Pipes
Description of what it does: It filters out items into designated chests, much like the item sorter, without taking up the room. You simply put a sign on a pipe piston to filter what goes into the chest/from the chest.
Link to it on the Craftbook Wiki: http://wiki.sk89q.com/wiki/CraftBook/Pipes
(ノ◕ヮ◕)ノ*:・゚✧
Mon Mar 02, 2015 6:32 pm
More Craftbook IC's and Mechanics have been enabled including:
Painting Switcher
Minecart Boosters
Minecart Speed Modifiers
Minecart Elevators
Minecart Stations
Minecart More Rails
Minecart Coasting
Pipe Filter Signs
I have not enabled PLC yet as I need to do some more research into what can be made with them.
Tue Mar 03, 2015 8:50 am
IC / Mechanic Name: MC1270 - Play MIDI file on relative area.
Description of what it does: once enabled, it will create a folder in craftbook folder where you play music file from there. MC1270 plays in radius or offset area ( http://wiki.sk89q.com/wiki/CraftBook/Search_Area ) thats means it doesn't play globally so it wont cause annoyance to online users.
Link to it on the Craftbook Wiki: http://wiki.sk89q.com/wiki/CraftBook/MC1270
Video
th3thrilld3m0n
CPU: Artificial Intelligence
RAM: 9001 TB
Motherboard: Your Mother
Display: IMAX 3D
Cooling: Fire
Wed Mar 04, 2015 10:17 pm
IC / Mechanic Name: Minecart Sorter
Description of what it does: Sorters allow the sorting of minecarts based on criteria matched against the minecart.
Link to it on the Craftbook Wiki: http://wiki.sk89q.com/wiki/CraftBook/Minecart_Sorters
This would allow me to create a destination-based minecart system.
th3thrilld3m0n
RAM: 9001 TB
Display: IMAX 3D
Cooling: Fire
Re: What IC's & Mechanics do you want enabled from Craftbook?
Sat Mar 21, 2015 12:46 am
noticed that this thread has gone unoticed
Users browsing this forum: No registered users and 38 guests
